Using the point_feature_definition property is not working. Is there some configuration variable that needs to be enabled to use this? Below is what I have setup but nothing annotates. The templates do use the appropriate feature definition.
What must I do to get annotate by feature definition working?
Hi Titus,
Based on your attached image, you have two feature definitions assigned and you can only have one. Assign either the first or second feature definition, not both, that should resolve your issue.
Sanders
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/33435/openroads-designer-connect-edition---wiki-articles-and-videos
After removing one of the feature definitions I'm still not getting any annotation. I can't seem to get the point_feature_definition expression to filter anything. Is there a configuration variable that must be turned on to enable this.
I now using the Filtered points list which works just fine.
