I started using line mode for designing,
While writing the code for horizontal alignment i came across "301 element data" and in help it was mentioned about different element types like FIX, FLOATING, and FREE.
May I know the difference between all the three types so that i can use the code accordingly
Thanks.
Using a straight as an example element.
FIX - does not need another element to connect to e.g. defined by 2 points
FLOAT - needs one other element to connect to, an arc before it, OR after it.
FREE - needs two other elements to connect to, and arc before it AND after it.
Thank You so much sir
