Hello dear users,
Is there a way to attach multiple Template Libraries at once?
I would like to attach a WorkSpace Template Library, where we have our standard building blocks, and a WorkSet Template Library, which are project related.
With kind regards,
Jasper
Jasper,
It seems you can only have one library open at a given time. You can use Template library Organizer to move template components between itl files.. So the default library to use would be the WorkSet.itl. Using TLO you can then open the WorkSpace.itl to drag components into the WorkSet.itl.
~HTH
John.
yep
You could also use your workspace template library as a seed for your workset template library. Copy the workspace library to your workset and rename it for your project.
Hi Ray, John,
Thanks for your reactions. This is actually how we managed it now. We have our functional management location at our WorkSpace directory and copy this to our WorkSet-Template for new projects. It seems there is no other solution at this moment to drag the updated building blocks to the current WorkSet instead of them updating automatically.
