Hello everyone. I am having trouble with the pipe crossing displaying correctly on profiles under GEOPAK drainage. In the example below, I have a pipe coming in at 3732.34 invert elevation, and the crossing pipe (in yellow) is also at 3732.34 invert elev. This profile is showing as if the soffit of the crossing pipe is at 3732.34, not the invert which is not the case. This is a matter of display issues because when redisplayed in other computers, it displays correctly. Is anybody having this same problem or know how to fix it? Thank you,
what version of geopak are you using? have you tried cleaning your resource files?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/15923/geopak-resource-files-how-to-remove-them-and-why
Thanks Nico. I tried to follow the steps to clean the resource files. It is still giving me trouble.
if the same files work fine on other computers, you may have an issue with your workspace.
try it with a different workspace, if that doesn't work, maybe you should do a clean install.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum#pi25841=1
Thank you Nico. I will try this now.
