I have a project need the MX ss2 version,
find out if install MX SS4, the previous version be swipe out.
Can MX ss2 and MX ss4 co-installed?
Hi
No you cannot have two V8i Versions on the same machine. You can have MX V8i SS4 and OpenRoads Designer CONNECT Edition on the same machine.
Hope this helps.
Simon Pegg
Bentley Civil Support
I thought that you could have SS2 & SS4 on the same machine, but not SS3 & SS4.Or am I thinking about InRoads/Geopak?
MaryB
I used to have MX SS2 and SS3 installed at the same time.
I might have been mistaken about SS2 and SS4 being on the machine at the same time, its been a while since I've had SS2 installed.
Best thing is to install SS2 and then try SS4 and see what happens.
Definetly do it this way round and not SS4 and then SS2
Apologies for the confusion.
Simon.
sorry, sort out have install ss2 and ss4 at the same time; just the IT admi issues.
