ORD Survey points are being placed on Default level
I am trying to configure ORD Survey settings. I have everything set and the points import correctly into a field book. My problem is all the point cells are being placed on the Default level. I defined different levels in the element template but ORD is not using the levels from the element template. What have I overlooked?
Parents Reply Children
