How to introduce transition in vertical curve in Inroads PRT SS4?
I already tried with element method but it shows error.
I've never seen a transition used in a vertical curve, what standard are you designing this to?
what do mean by "Stanadard"?
And I already saw a video for vertical curve. So I think you should see that also....
Speed?
By 'Standard', I think Alex means what design standards are you working to. In the UK, for example, we use TD 9/93 for highway design. If you have seen a video, please give a link to it if you want others to see it.
Yes, I share here that link :
https://www.youtube.com/watch?v=mgfFLMe2e60
Regarding standard I got you Mark but I cannot reveal. Yes, but I tell you it is High speed design like 140 m/s and standard is only for particular project.
