I have a question in regards to template drops. For visualization purposes the client wants to split the template drop into segments of 2m (for example). I know I can do this manually and calculate the stations for each segment, but the corridor is really long and it should be split into roughly 721 segments. My question is if there is any simple way to this in PowerCivil, like introduce a template drop length or the stations without me clicking 1042 times?
Thank you
Andrei
Thank you for your reply. The only reason is that the client wants to use it for visualization purposes and use it to create a sequence.
