I'm using MX Roads SS4. I'm trying to trim some element using Intelli Trim (Quick Mode). I'm following the prompt "Identify element to trim to" and "Create line crossing the element.." But after that, it's not trimming the element. Can anybody kindly suggest why it's happening? Other trimming option, such as "Trim to intersection" and "Trim multiple" etc are working correctly on the same element.
Thanks in advance
snehasish mondal said: it's not trimming the element
What type of element are you attempting to trim? Not all elements are suitable for trimming. Some elements may not be modified other than by the owning application (in your case MX Roads).
Elements are Line/Arc/Complex element. As I already mentioned, the same element can be modified with other trimming tool.
Hi Snehasish Mondal,
Please post your thread in the civil forum https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum#pi25841=1
I might suggest you are using the command wrong. The first element to select is the one that is used as the cutting edge. The line (or points) is for the elements to be trimmed. This command can also operate using a selection set.
