When using storm drain elements in SUDA, I am unable to modify the physical rim and invert elevations so that the structure type has a height less than 5.32 ft. However, the true structure elevation can exceed this depth. Is this a constraint that can be modified in order to achieve an inlet depth less than 5.32 ft?
Derrick: The default behavior of SUDA is to never allow you to place a node which is more shallow than 1 meter. In order to overcome this you need to add the following configuration variable to your workspace:
DEFAULT_UTILITY_NODE_HEIGHT = 0.1
The value can be any number. I use 0.1 because it maximizes my ability to be an engineer and minimizes the "help" provided from the default behavior of 1 meter depth.
Robert Garrett Senior Consultant
www.envisioncad.com
