I'm trying to create a terrain from a Graphical Filter by Feature Definitions. The Filter Group has a Filter for Break Lines and a Filter for Spots.
Whenever I run it, I get an error of "No Matching Elements Found" even though there are definitely elements with those Feature Definitions.
Also, whenever I try to create a new Filter by selection set, it doesn't populate the Feature Definitions option.
Any help is appreciated!
Thanks!
OpenRoads Designer CONNECT Edition - 2018 Release 3 Update 5 - Version 10.05.00.30
Do you have a DGN with the terrain and a stored terrain filer group so we can test in the latest release? This was reported in the SS4 version by a few users but I haven't seen anything mentioned of an issue in ORD CONNECT, so I would need to test.
The user in SS4 experiencing the issue mentioned it works much better if they are in a 3D view, so that could be something to test: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/168007/graphical-feature-filter-not-selecting-all-features-that-match/496962#496962
Chris,
See the attached file for example.
It has the terrain filter group stored that I would like to use to create a terrain by feature definitions.
I had no luck trying it in the 3D view.
Seed3D - Imperial Design.dgn
Chris, have you gotten a chance to test this yet or have any suggestions?
I'm watching this as well. In the SS4 environment this tool was hinky. Please post back results.
Cliff
The same issue in OpenRoads 10.07.It seems the problem is caused by parameter "Elevation exclusion" in filter.When I switch OFF this parameter, terrain is created. When I switch ON this parameter, terrain is not created and "No matching elements found" message.That is funny, because Preview button in dialog command works regardless parameter settings.
