ORD - Create Super Single Control Control Line by Station or Lane Line
I need to create a single super control line for an auxiliary lane from Station x to Station Y and then apply this to the point controls. I went to create the single super and there was no option to create by station or read the auxiliary lane line. I have the lane line created and I now want to apply a super to this Auxiliary lane. Is there a provision or workflow for this somewhere? I just can't seem to find the answer.
thanks in advance
Parents Reply
  • Marc, I solved this issue. In the Plan view select the pavement lane that is not honoring the Mirror Cross-Slope. In the Project Explorer find the Transition. Change Mirror Cross-Slope to NONE. You will note in the Superlevation View the cross-slope is now mirrored. Now switch back the NONE to Mirror-Slope for future changes.
    Must be a clitch in the software. Perhaps you should let the developers know.
    Thanks Again,
    Joe Lukovits
    User Since TDP in the 80's,
    Vax based Unix Workstations - Interpro32,
    from the Intergraph Corp.
