I have some corridors that intersect with each other. I would like to trim or cut one of them with the other where they intersect. I tried with corridor clipping but that does not work for me. I am looking for something similar to Boolean Operation in Rhino.
Clipping with the corridor should work. Make sure you are picking the 2d corridor object as the clipping reference. You can also draw a simple microstation shape and use that to clip with. I prefer that method as it is much faster (the more clips you add and the more complex those clips are the slower the corridor processing becomes).
Marc
Hi Marc,
I tried the corridor clipping but the result is not what I am looking for.
Hi Andrei,
Looks like you're looking for Boolean Corridor Clipping for clipping of intersecting 3d elements. There is one in the works but it is not ready yet apparently.
I would create a CAD boundary or seperate corridors to get the clipping to work.
Mark
Answer Verified By: Andrei Chiriac
Thank you. That is what I was looking for, but since it's in the works I will try something else. Where can I find a workflow that would help me?
Thank you
