unable to modify the super elevation neither graphically nor in the table _Open Roads
I am facing problem in super elevation application. by default it is showing AASHTO rules. since the project site is in middle east (Oman) , I would like to modify the super elevation rate and stations.
In Bentley website videos it is shown that we change graphically both stations and S.E. But I couldn't able to do it. even in the table ( below picture) also I am not able to change stations. please help me in solving this.
Parents Reply
  • I think the problem may be that all of the AASHTO rule constraints are preventing you from making the precise edits you want. Some fields are greyed out because they are constrained to other superelevation points.
    Try changing all of the constraints in the table to "None" and then making your changes. I usually get an error during the process of removing the constraints. All you have to do it close the superelevation editor, save and re-open the dgn. The error doesn't result in loss of data.
    I've started importing my superelevations from CSV instead of using the automatic calculations, that way there are no constraints to remove.
