Hi all,
I have a DGN which crashes whenever I try to create an ORD Profile drawing whilst it is located on Projectwise - giving me a "File does not exist" message. How can it not find itself? It happens immediately on trying to create a drawing (see attached exception.log).
Other DGNs are working fine, except this and it works okay when stored locally - is there a pathing variable issue, etc?
7633.exception.log
Mark
Hi Mark, can you provide your dataset and I will try to reproduce the issue? You can upload it here: https://bentley.sharefile.com/r-r86847128fa74cd69
Thanks Marc, uploaded
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Marc,
I have also confirmed this only crashes if I select a Drawing seed in the Create Drawings dialog.
I tried it and it doesn't crash on my side. Maybe the references?
Hmm can't reproduce it anymore, will keep an eye on it for next time.
Thanks Marc!
