default cell scale factor
I am migrating from InRoads SS3 to ORD. In SS3 we had the Project Options set to use a Text Scale Factor of 25 and a Cell Scale factor of 25. How do I set a default cell scale factor in ORD? My survey points are coming in too small and need to be scaled up by a factor of 25. The only way I know to accomplish this is to edit the DGNLIB file and add a cell scale to each of the survey point code cells. Is there a global setting for the survey point cells?
