Where can you change the vertical exaggeration of a profile model in the OpenRoads product? There is not an option in any command settings to set this. When I go to the View Attreibutes - Civil - Exaggeration, there is a drop down menu. My Customer requiresa 6' exaggeration not 5 or 10, so how do I change this? I'm the only person running this software in my office, and I'm learing it by bentley online - so where do I find help for this?
There is a configuration variable CIVIL_EXAGGERATION_VALUES that lists the available values. Amend the variable by (1) File > Settings > Configuration > Configuration Variables or (2) edit the relevant configuration (.cfg) file in a text editor to add the value you need.
Answer Verified By: Auda Freemon
This only controls which values it offers in the drop down menu. Can we also set a default value to use?. In Ss4 a save settings does not seem to work. Plus, since it is recommended that you not save settings with Cross Section or Profile Views open, this is not much help.
Do you know when the second variable was added?
These were included prior to ORD CE Update 3. I am sorry but I cannot give you a more exact answer as I have not saved my cfg files from versions before that.
Mark
When I search all the configuration variable i do not see these two variables. Are the Civil Configuration Variables somewhere other than File-->Settings-->Configuration-->Configuration Variables?
CIVIL_EXAGGERATION_VALUESCIVIL_SET_DEFAULT_EXAGGERATION
Brian
OpenRoads Designer 10.09.00.91
If the variable is undefined it may not appear in dialog.
see docs.bentley.com/.../GUID-812ED418-FF79-E283-D201-2D6817440262.html
Thanks Mark, that's good to know
