Is there a solution to the existing ground showing up on top of the design surface in a cut area?
I have a road that has a fairly large cut section but when I take it to Lumen to render and animate it the existing ground shows up on top of the proposed surface.
So the only design surface I can see is areas that the grade is higher.
Parents Reply Children
