LIDAR LAS to POD point cloud conversion scaling issue.
We're evaluating Openroads Connect Edition and one thing we're having problems with is the scaling of point clouds. I have converted the same LAS file using GeoPak and have not had any problems. The scale seems to be 3X the Geopak POD file and what dimensions should be. The units are Imperial and I'm using the provided Seed3D - Imperial Design seed file. Has anyone else had the same issue? Thanks.
