Openroads Terrain
Hi.
I've created a terrain model from spot level from a referenced dwg file using graphic filter method. Triangulation was done smoothly. But I'm facing a lot of issue working with the terrain model. As you see in the attached screenshot, irrespective of the contour interval, no contour is being generated. I've tried this both by activating and deactivating the rules. There is no problem with displaying the triangles though. Kindly help.
I'm using Openroads Designer Connect Edition 2018 Release 2.
Parents Reply Children
