While I look on migrating from InRoads Survey (SS2, because it was the last working version in german) I found an expanded list of link codes in ORD 10.4 or 10.5, but I can't find a documentation for the meaning of this codes, especially the different ones to InRoads Survey. Has anyone such a document?
Best regards
Steffen Roemer
Take a look at this. Have you seen this? https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/7058/transitioning-to-bentley-civil-survey-document
Thank you, Cliff,
this was what I missed. But I looked for Migration, not Transition...
Another question - I can't find a tool like the InRoads Fiedlbook to edit the survey points - edit code errors, adding attributes etc. What is the way for this?
In OpenRoads all survey database navigation is through the Project Explorer. I added a capture below.
Blue = project explorer
Red = survey details
The survey details tools is where the survey data is located. This allows for editing of the points through a columnated format.
Cliff
Steffen
Have you looked at the QuickStart For Survey on the LEARN Server?
https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=110831
Also, in OpenRoads Designer, you would open the Survey workflow (from the top left dropdown) to access the survey functionality. Explorer will show your data, as the example screenshot shows below.
Steffen mentions 'ORD 10.4 or 10.5' - your image is from one of the SELECTSeries 4 products - which contain OpenRoads technology but which are not the same as OpenRoads Designer.
Just to clarify the difference from the image in your post and the one I posted.
