Hi
I'm trying to export alignment from ORD to MXGenio.
I'm importing the alignments from Inroads in both LandXML v2.0 and straight from the alg's. No matter what method i use i always get an error saying error exporting to MX Genio be it for one string or a group of strings.
I got it to work once but since then no matter how many restarts or new seed files i use i get the same error with no additional details.
kerbs.xml
<?xml version="1.0" encoding="iso-8859-1" ?> <LandXML xmlns="http://www.landxml.org/schema/LandXML-1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.0 http://www.landxml.org/schema/landxml-1.0/LandXML-1.0.xsd" version="1.0" date="2019-01-22" time="15:05:14"> <Project name="404-200-M41W-M42W" desc="Bridge 82 WWE over Dudley Street"> <Feature code="GridScaleFactor"> <Property label="GridScaleFactor" value="1.000000000000"/> </Feature> </Project> <Units> <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA"/> </Units> <Application name="Bentley InRoads Suite V8i (SELECTseries 2)" manufacturer="Bentley Systems, Inc." version="08.11.07.615" manufacturerURL="www.bentley.com"/> <Alignments> <Alignment name="M41W" length="446.1952930" staStart="1000.0000000" state="proposed"> <CoordGeom name="M41W" state="proposed"> <Line length="98.0624053" dir="2.559189899" staStart="1000.0000000"> <Start code=""> 5813223.566852 318981.203093 0.000000 </Start> <End code="TC "> 5813141.670674 319035.140570 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="ccw" crvType="arc" length="93.1948968" chord="92.8864427" dirStart="2.559189899" dirEnd="2.277208366" staStart="1098.0624053" radius="330.5000000"> <Start code="TC "> 5813141.670674 319035.140570 0.000000 </Start> <Center code="CC"> 5813323.456305 319311.155487 0.000000 </Center> <End code="CT "> 5813072.046362 319096.625092 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="44.9347017" dir="2.277208366" staStart="1191.2573021"> <Start code="CT "> 5813072.046362 319096.625092 0.000000 </Start> <End code="TC "> 5813042.878860 319130.806728 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="cw" crvType="arc" length="30.9868463" chord="30.9790987" dirStart="2.277208366" dirEnd="2.354675482" staStart="1236.1920039" radius="400.0000000"> <Start code="TC "> 5813042.878860 319130.806728 0.000000 </Start> <Center code="CC"> 5812738.600563 318871.163285 0.000000 </Center> <End code="CT "> 5813021.872589 319153.576031 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="56.9734799" dir="2.354675482" staStart="1267.1788502"> <Start code="CT "> 5813021.872589 319153.576031 0.000000 </Start> <End code="TC "> 5812981.647497 319193.923514 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="cw" crvType="arc" length="39.2902857" chord="39.2779986" dirStart="2.354675482" dirEnd="2.441313377" staStart="1324.1523301" radius="453.5000000"> <Start code="TC "> 5812981.647497 319193.923514 0.000000 </Start> <Center code="CC"> 5812660.487837 318873.738063 0.000000 </Center> <End code="CT "> 5812952.737415 319220.512390 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="46.9494478" dir="2.441313378" staStart="1363.4426159"> <Start code="CT "> 5812952.737415 319220.512390 0.000000 </Start> <End code="TC "> 5812916.836945 319250.768082 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="ccw" crvType="arc" length="32.0586229" chord="32.0460179" dirStart="2.441313377" dirEnd="2.344166035" staStart="1410.3920637" radius="330.0000000"> <Start code="TC "> 5812916.836945 319250.768082 0.000000 </Start> <Center code="CC"> 5813129.499263 319503.106622 0.000000 </Center> <End code="CT "> 5812893.364190 319272.584980 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="3.7446064" dir="2.344166035" staStart="1442.4506866"> <Start code="CT "> 5812893.364190 319272.584980 0.000000 </Start> <End code=""> 5812890.748394 319275.264474 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> </CoordGeom> <Profile> <ProfAlign name="M41W"> <PVI> 1000.000000 13.265007 </PVI> <ParaCurve length="180.0000000"> 1103.235319 17.411180 </ParaCurve> <ParaCurve length="46.2034986"> 1372.228858 3.961503 </ParaCurve> <PVI> 1399.385653 4.111698 </PVI> <PVI> 1446.195229 4.151000 </PVI> <Feature code="ProfAlign"> <Property label="style" value="vert1"/> </Feature> </ProfAlign> </Profile> <Feature code="Alignment"> <Property label="style" value="WGT_SOP"/> <Property label="guid" value="afe73685-9a69-4f01-9326-c312f69573cd"/> </Feature> </Alignment> </Alignments> </LandXML>
<?xml version="1.0" encoding="iso-8859-1" ?> <LandXML xmlns="http://www.landxml.org/schema/LandXML-1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.0 http://www.landxml.org/schema/landxml-1.0/LandXML-1.0.xsd" version="1.0" date="2019-01-22" time="15:05:38"> <Project name="404-200-M41W-M42W" desc="Bridge 82 WWE over Dudley Street"> <Feature code="GridScaleFactor"> <Property label="GridScaleFactor" value="1.000000000000"/> </Feature> </Project> <Units> <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA"/> </Units> <Application name="Bentley InRoads Suite V8i (SELECTseries 2)" manufacturer="Bentley Systems, Inc." version="08.11.07.615" manufacturerURL="www.bentley.com"/> <Alignments> <Alignment name="M42W" length="615.6749018" staStart="2000.0000000" state="proposed"> <CoordGeom name="M42W" state="proposed"> <Line length="91.6337422" dir="2.559189882" staStart="2000.0000000"> <Start code=""> 5813224.996934 318983.374464 0.000000 </Start> <End code="TC "> 5813148.469613 319033.775971 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="ccw" crvType="arc" length="111.2178795" chord="110.6223676" dirStart="2.559189882" dirEnd="2.200422528" staStart="2091.6337422" radius="310.0000000"> <Start code="TC "> 5813148.469613 319033.775971 0.000000 </Start> <Center code="CC"> 5813318.979590 319292.670444 0.000000 </Center> <End code="CT "> 5813068.422811 319110.129214 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="42.7894504" dir="2.200422529" staStart="2202.8516217"> <Start code="CT "> 5813068.422811 319110.129214 0.000000 </Start> <End code="TC "> 5813043.226556 319144.713687 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="cw" crvType="arc" length="95.4564251" chord="95.3366641" dirStart="2.200422528" dirEnd="2.373979665" staStart="2245.6410720" radius="550.0000000"> <Start code="TC "> 5813043.226556 319144.713687 0.000000 </Start> <Center code="CC"> 5812598.690336 318820.850215 0.000000 </Center> <End code="CT "> 5812980.621114 319216.613883 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="108.0928020" dir="2.373979665" staStart="2341.0974971"> <Start code="CT "> 5812980.621114 319216.613883 0.000000 </Start> <End code="TC "> 5812902.840744 319291.675643 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> <Curve rot="cw" crvType="arc" length="47.1676068" chord="47.1274664" dirStart="2.373979665" dirEnd="2.516911807" staStart="2449.1902991" radius="330.0000000"> <Start code="TC "> 5812902.840744 319291.675643 0.000000 </Start> <Center code="CC"> 5812673.682277 319054.217442 0.000000 </Center> <End code="CT "> 5812866.678956 319321.896880 0.000000 </End> <Feature code="Curve"> <Property label="style" value="WGT_SOP"/> </Feature> </Curve> <Line length="119.3169958" dir="2.516911807" staStart="2496.3579059"> <Start code="CT "> 5812866.678956 319321.896880 0.000000 </Start> <End code=""> 5812769.894997 319391.678044 0.000000 </End> <Feature code="Line"> <Property label="style" value="WGT_SOP"/> </Feature> </Line> </CoordGeom> <Profile> <ProfAlign name="M42W"> <PVI> 2000.000270 13.343148 </PVI> <ParaCurve length="168.9231394"> 2100.078453 17.090418 </ParaCurve> <ParaCurve length="227.3896755"> 2370.325903 4.383885 </ParaCurve> <ParaCurve length="13.0000000"> 2524.425365 4.925220 </ParaCurve> <PVI> 2547.967890 5.129432 </PVI> <PVI> 2615.700241 5.794246 </PVI> <Feature code="ProfAlign"> <Property label="style" value="vert1"/> </Feature> </ProfAlign> </Profile> <Feature code="Alignment"> <Property label="style" value="WGT_SOP"/> <Property label="guid" value="82e88f7f-6405-4224-90e7-87492c79a630"/> </Feature> </Alignment> </Alignments> </LandXML>
Iv tried on other computers and its working once only on each before reverting to the same error continuously, regardless of restarts or new seed files.
Git it!
You need to make sure your ALG's alignments are named with exactly 4 characters both the Hz and Vz alignments. Any more than this and the export fails. Seem logical in hindsight but when some are and some aren't it was troublesome to figure out.
Answer Verified By: David Marx
That's weird - the alignment name is remapped on GENIO export using the feature definition?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
