Hi there,
I run some EAV reporting and compared it with what is shown on the cross section - I noticed there are discrepancies between areas in report and areas measured from cross section. An example is shown on the screenshot. Can someone from Bentley explain why there is a difference in values? Ideally, I would like to understand in depth how EAV works in ORD world knowing ORD generates real cut/fill volumes.
Regards,Krzysztof
Krzysztof
Can you share some data please ?
Simon Pegg Bentley Civil Support
PS I have picked up the SR. You can either attach some data here, or on the SR, or email me direct.
Sure but it's quite big dataset. You can try to reproduce the issue on simple corridor...
Any findings?
