ORD CONNECT 2018 R4 U6 10.06.00.38
I am currently working through the training module for viewing cross section models. When I got to the section for "Cut & Fill Graphics and Values" I went to the View Properties pull down and tried to click on "Display Cut & Fill Graphics " along with "Display Cut & Fill Values". When I clicked on one of the two boxes the dialog box disappears. I reopen it and click again, but it keeps disappearing and the box is not checked. After doing this a few times the dialog allowed me to check the boxes, but the display does not change. Upon reopening the dialog the boxes are not checked again. This is with the Bentley supplied dataset. I talked with a few co-workers who are working with a client supplied workspace and they are experiencing this same issue. They also stated that this worked in the previous version of ORD.
Can anyone verify that this functionality is lost with this version?
Thank you for the response Marcus!
Was this defect fixed in a later version of ORD Connect?
Hi Krissy,
This works fine in ORD 2019 Release 2.
Mark
Thank you!
