Hi.
While using a 3D seed file, the "Default-3D" in saved views does not appear. And also, in 3D view both of the "Current Active Linear 3D Element", and the "Complex element" for the same 3D Element appears. It creates confusion in 3D views. This does not happen while using 2d Seed file. Can anyone suggest any material to elaborate how these seed file works and when to use 2D and when to use 3D seed file. Additionally, in my design I have used a 3d seed and getting 2 lines for each element which is very confusing and messing with the 3D Model. What can be done about that?
Thanks in advance.
Hello Chuck. The link to the document doesn't seem to work. I would like to see what you posted.
Thanks Cliff
I just edited the post and it seems to work now. Sorry for any inconvenience.
Thanks Chuck!
This pdf tells about a lot of thanks in depth, thank you.
