I am trying to use some of the DGNLIB files delivered with ORD Civil Default Standards - Imperial Workspace. When I try to open the file, I get a message "The data in this file belongs to [OpenRail Designer Update 3]." I have tried using the Version Checker to align the products but it fails every time. I get an error "VersionChecker.exe has detected a problem and logged it to ..."
Is there any other method to convert an OpenRail file to an OpenRoads file?
I just want to use the sample files as a starting point to configure OpenRoads Designer profile and cross sections labels.
What does the log file say that the problem is? What version of ORD are you running?
ORD 2018 Release 4 Update 6 ver 10.06.00.38
The exception log does make any sense to me. Do you know what this means?
Exception 0xe0434352 at Wed Jan 30 10:19:00 2019
VersionChecker version ?.?.?.?
Exception String: '*Unknown*'
Memory Statistics for process ID 7460:
16303 MB Total Phys 10817 MB Avail Phys 65453 MB Total Page File 59633 MB Avail Page File 8388607 MB Total Virtual 8387825 MB Avail Virtual 0 MB Avail Extended Virtual
90 MB PeakWorkingSetSize 90 MB WorkingSetSize 48 MB PagefileUsage 50 MB PeakPagefileUsage
30376 PageFaultCount 775272 QuotaPeakPagedPoolUsage 706664 QuotaPagedPoolUsage 69824 QuotaPeakNonPagedPoolUsage 66272 QuotaNonPagedPoolUsage
76 GDI Objects 41 USER Objects
Dale
Civil 3D 2018, ORD 2019 Rel 1, InRoads SS3
Drug kicking and screaming into the world of InRoads & ORD!!
No, but let me see what I can find out.
Mark I have a vague memory that version checker has problems on Windows 7, might be worth seeing if this is the case and if they can try on windows 10
Answer Verified By: Dalek
Is it a specific file that is causing the issue? If so, which file is it?
