I the get the error below when I open a file in OpenRoads Designer CONNECT Version 10.03.00.43 after the file was worked on in OpenRoads Designer CONNECT Version 10.05.00.30.
How can this be fixed? Can I save it down to an earlier version?
Hi , Carl
you can’t save back the file. Update your install of open roads designers the latest version. R6
Hi Eric,
I thought that might be the case.
So anybody we send the file to will have to have the same version or newer in order for them to use it, correct?
The R6 version uses Bentley’s new CONNECT Licensing yes?
Yes. Be carefull what you share in terms of version
there are 4 update releases a year
