Create a terrain model, display contours. I do not want to see labels. Doesn't matter why, I just don't.
So, my element template has Display text as False for major and minor contours.
However, the element template still has a text style set from wherever I copied the template.
The contour labels are still shown, unless I set the text style to None.
Hi Robert,
I've found that Element Template changes don't seem to be implemented in some circumstances unless you toggle your feature definition to something else and back again. It didn't work like that in SS4 as far as I can recall.
Mark
