I'm defining some ramps to acces a parking. So I created profile for my civil geometry, I then did a terrain model with the elements. Now I would like to add more "points" in my 3D linear features. Is there a way that I can specify the software to add points to help a better triangulation? In my example below I would like to add point on both center and right tangent to have a better triangulation with the curve. I'm suspecting the 3D generation of the elements is base on stroking parameters, mainly because on my center tangent I have a straight profile and it's generated a point every 10m like my variable "civil_default_stroking" was set. So I change it to 2m but nothing change. So on what parameter is this generated? Or what can I do beside adding manual breakline?
Hey wow thanks to you I just found out that there was a stroking parameter in the property of the element! it's just not in the help files. So yes change it there and everything is fixed. Thanks again for your fast answer.
Answer Verified By: Chris Key
