When creating multiple plan-sheets of a road in ORD CE, isn't it possible to manage the level display for all sheets at the same time..?
I have 27 sheets for a 30 km road and it seems really pointless that I have to open every single sheet to hide the same 10 levels, over and over again.. And if, for some reason, ORD decides to not save these level display settings (even though I keep hitting "save settings"...), I will have to do the same thing next time I open the file....
Good afternoon,
I was trying to figure this out my self and I found a way to turn off or keep from printing the levels for all sheets. Go to level manager>right click on the level you want off on ALL sheets>select properties>here you can "uncheck" the boxes that say display and or plot. This will turn off the level and keep it from printing on all your sheets. I hope this helps.
Hey Mark,
I've been dealing with the same issue where the level display in my design model does not control the display in my sheet models. I checked the config and saw that this variable was already set to 1, shown below. Am I missing something?
