Could any one can help on this.
I want to create interface as in below image. If it is cut its a different section which I have no problem. When it comes to fill location, couldn't able to create a flat string from the 1in3 slop string which is interfaced to ground model from there for offset of 15m flat following berm as shown in image.
INTERFAC,RAIL GMC NEW TRIA,RAIL GMC NEW259,INTI260,M000,2=IA00,3=IB00,4=-1,5=35000,8=53500
000 FILL262,TX00,2=C000,3=IB01,4=5,7=-0.33333333262,IGN ,2=IB01,3=IB02,4=3,5=15.0,7=0262,IGN ,2=IB02,3=IB03,4=5,5=04.0,7=0.5262,IGN ,2=IB03,3=IB04,4=3,5=01.0,7=0262,TX00,2=IB04,4=5,7=-0.5
000 CUT261,IGN ,2=C000,3=IA01,4=5,5=3.6,7=-0.33333333261,IGN ,2=IA01,3=IA02,4=3,5=6.0,7=0261,IGN ,2=IA02,3=IA03,4=5,5=3.0,7=-0.33333333261,IGN ,2=IA03,3=IA04,4=3,5=5.0,7=0261,IGN ,2=IA04,3=IA05,4=5,5=3.0,7=+0.33333333261,TX00,2=IA05,4=5,7=0.25263,DISC999
Many thanks in advance.
what product and version are you using?
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/175005/is-it-possible-to-write-261-to-the-interface-string-which-is-already-interfaced-to-ground-model
Hi Nico,
Thanks for the reply.
MX Road. V8i (SELECT Series 4).
While it is very hard to see what you mean from your image (it is very small) - one work around could be to use stored sections (which are the same i.e. both go through TX00) and interface to set 1, and then look for set 2?
Hi Mark
Thanks for your replay.
Sorry, hope the image showing the section is clear. And couldn't able to understand what exactly your answer represent.
Again my question is , assume the image is for fill location.
I couldn't able to create a flat string, from the 1in3 Slope string (slope showing varies in image to the right of HCL) which is interfaced to ground model from there for offset of 15m flat following berm (4H and 2V, 1m Flat & 4H and 2V) as shown in image.
Look at the Help file - inferface Examples 13 -15. Take 2 sets of sections through the triangulation, and interface to the first set with the 1:3 slope, and then go up (say) 5m, across 15m and down to second set of sections to get the start of the outside berm.
