Hi.
I just moved the configuration files from my C drive to another local drive. Changed the Workspace setup configuration file in my C drive. I've changed the following,
1. MY_CIVIL_ORGANIZATION_ROOT
2. MY_WORKSPACES_LOCATION.
3. MY_WORKSET_LOCATION.
Initially I did not change the workset location as I wanted to save my wrkset within the default location within workspace.
The problem is, after doing the set up, though the workspace and workset is directed to the new location, but no feature definition is appearing while working in the dgn. I followed the steps as per the video in learn server.
Unable t figure out what I'm missing. Any help on this regard will be appreciated.
Thanks in advance.
Hi, Can you share your cfg files and your configuration values? You can find the latter in File / Settings / Configuration / Configuration Variables then File / Show Configuration Values
Thanks for your reply. Kindly find enclosed the workspace set up and configuration values.
.4456.configVariables.txtWorkSpaceSetup.cfg
Have you moved the 'WorkSpaceSetup.cfg' file to the new location?
No, actually. But as you asked, I tried with moving the set up file to new location, it did not help.
You haven't removed the # at the beginning of the line: #MY_WORKSET_LOCATION =J:\E data\20.L&T Openroads\Configuration\WorkSpaces\Metric Standards\WorkSets
