I have a question regarding the template interval drop, more exactly can it be changed in the curved parts of the alignment. No matter how high I set the values for the interval drop (let's say 1000m), in the curved parts it is still placed at a certain interval (let's say 5m).
Can this be changed?
I think you need to look at the CIVIL_DEFAULT_CURVE_STROKING variable - i have it set to 0,02m, so a template will be dropped when the straight chord gets further than 0.02m away from the curve.
Answer Verified By: Andrei Chiriac
In the picture above this is what I am talking about. It seems that PowerCivil places some sections at small intervals and I want to increase that interval. I tried the CIVIL_DEFAULT_CURVE_STROKING variable and increased it to 1000 but it is still the same.
You'll need to know what design stage your corridor is using, so look for that in that corridor's element information.
Within the Project Explorer (you probably have it open, but in case, File > Project Explorer), go to the Civil Standards tab. Look for Project Settings > Corridor Design Stages. Look for that design stage, and click it. In element information, look for Include Critical Sections. Your cardinal points are probably on, and it sounds like you want them to be off.
