I am attempting to create drawings using the Detailing Symbols commands but can't find any tutorials (print or video) that walks me through configuring everything that goes into it. For instance, When I use the "Place Section Callout" command to cut a cross section I define where I want the section cut and then the "Create Drawing" menu opens. From there I can name the section and I can pick the annotation scale and detail scale but when I click OK I receive an error message that ultimately tells me it "Failed to attach drawing to sheet" and nothing happens.
Are there instructions somewhere that will walk me through setting everything up so that I can create drawings using Detailing Symbols?
Thanks for any information you may have.
Hi Chris,
this is MicroStation Programming group. Is your question about to solve the issue programmatically?
With regards,
Jan
