How can I get 2 surfaces to show up on my cross sections? I can get my existing surface to show up but that is it.
Thanks!
Which software package, and which version are you using? There are significant differences between packages, and even between some versions.
The answer to your question could be very different, depending on what you use.
MaryB
InRoads 081109878
Microstation 081109832
Hey Jess: Hope all is well with you.
The cross-sections are direct reflection of whatever is shown in the 3D model. For example, the workflow culd go like this:
A side note: I had a project from one of our designers come across my desk some time ago where a bunch of stuff was missing in the cross-sections. Turns out he had somehow made all the corridor feature as construction class. I have no idea how he did this (neither does he ) but when I turned on constructions in View Attributes for the cross-section model then they appeared.
Robert Garrett Senior Consultant
www.envisioncad.com
Hi Robert!! Great to hear from you!
I will pass this along and see if this helps. thank you :)
