I created templates, dropped them on the corridor and then added transitions between and everything was correct. Then I had to edit my templates with a new width. Which by the way, syncing 3 templates to over 50 template drops is a real time suck, should put a multiple selection edit tool to sync all 50 at once. Anyway, after my templates were correct and I updated the corridor drops, my transitions are not updating they still catch way outside my template drops.
Any help would be great. Thanks
That's a limitation of them since the first OR - definately a needed enhancement!
You'll need to recreate them as far as I know.
Mark
Answer Verified By: tforsman
Hi Mark
This problem was solve in the new version of OR ?
Iván
