I have created an overpass profile in PowerGeopak SS4 V08.11.09.904(Figure 1) but encountered an issue when trying to import it in Openroads Designer V10.06.00.38(Figure 3). When imported in Openroads Designer, it create a tangent line from PI of Sag Curve to PI of Crest Curve which resultPDF in Kink when creating a corridor model(Figure 3).
Files has been uploaded.
Thank you. I can confirm the problem. I will file it as a defect. I did export the chain and profile from cogo as landxml and that imported fine. try it
<?xml version="1.0" encoding="iso-8859-1"?> <LandXML xsi:schemaLocation="http://www.landxml.org/schema/LandXML-1.2 http://www.landxml.org/schema/LandXML-1.2/LandXML-1.2.xsd" version="1.2" date="2019-02-20" time="13:23:45" xmlns="http://www.landxml.org/schema/LandXML-1.2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <Project name="test" desc=""/> <Application name="GEOPAK" desc="Export COGO Chain to LANDXML." manufacturer="Bentley Systems, Inc." version="08.11.09.903" manufacturerURL="http://www.bentley.com"/> <Units> <Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA"/> </Units> <Alignments> <Alignment name="MAIN" length="2042.387959" staStart="5000.000000"> <CoordGeom name="MAIN"> <Line length="108.64297235" dir="5.82900760"> <Start name="MAIN1">2892293.91068750 453866.85247465</Start> <End name="MAIN-1">2892391.53966249 453819.18824610 0.000000</End> </Line> <Curve name="MAIN-1" radius="750.00000000" dirStart="5.82900760" dirEnd="6.10907225" chord="209.36268736" crvType="arc" length="210.04848993" rot="cw"> <Start>2892391.53966249 453819.18824610 0.000000</Start> <End>2892590.65630885 453754.49438240 0.000000</End> <Center>2892720.58231131 454493.15481445 0.000000</Center> <PI>2892486.53852824 453772.80808438 0.000000</PI> </Curve> <Line length="243.60891942" dir="6.10907225"> <Start name="MAIN-1">2892590.65630885 453754.49438240</Start> <End name="MAIN-2">2892830.58200174 453712.29287164 0.000000</End> </Line> <Curve name="MAIN-2" radius="750.00000000" dirStart="6.10907225" dirEnd="0.81083375" chord="709.21021732" crvType="arc" length="738.71010525" rot="cw"> <Start>2892830.58200174 453712.29287164 0.000000</Start> <End>2893504.15434967 453934.28256613 0.000000</End> <Center>2892960.50800420 454450.95330370 0.000000</Center> <PI>2893226.92461926 453642.57854869 0.000000</PI> </Curve> <Line length="259.87090522" dir="0.81083375"> <Start name="MAIN-2">2893504.15434967 453934.28256613</Start> <End name="MAIN-3">2893683.17793939 454122.65305667 0.000000</End> </Line> <Curve name="MAIN-3" radius="750.00000000" dirStart="0.81083375" dirEnd="0.24177870" chord="421.05600914" crvType="arc" length="426.79129110" rot="ccw"> <Start>2893683.17793939 454122.65305667 0.000000</Start> <End>2894047.25180990 454334.16754707 0.000000</End> <Center>2894226.82428486 453605.98231910 0.000000</Center> <PI>2893834.28483075 454281.64930576 0.000000</PI> </Curve> <Line length="54.71527524" dir="0.24177870"> <Start name="MAIN-3">2894047.25180990 454334.16754707</Start> <End name="MAIN2">2894100.37561680 454347.26802359 0.000000</End> </Line> </CoordGeom> <Feature code="Alignment"> <Property label="style" value="Default"/> <Property label="vn" value="60 "/> </Feature> <Profile> <ProfAlign name="MAIN_P"> <PVI>5000.000000 20.576306</PVI> <ParaCurve length="35.630181">5283.690000 16.179111</ParaCurve> <ParaCurve length="224.000000">5570.950000 12.568000</ParaCurve> <ParaCurve length="425.000000">5895.450000 24.250000</ParaCurve> <ParaCurve length="150.000000">6275.470000 9.049200</ParaCurve> <ParaCurve length="35.000000">6437.110000 7.871956</ParaCurve> <ParaCurve length="100.000000">6663.040000 5.292847</ParaCurve> <ParaCurve length="35.000000">6923.540000 7.031284</ParaCurve> <PVI>7042.387959 7.127000</PVI> <Feature code="ProfAlign"> <Property label="style" value="Default"/> <Property label="vn" value="2"/> </Feature> </ProfAlign> </Profile> </Alignment> </Alignments> </LandXML>
Answer Verified By: JSP
