Hello communiy,
I'm having trouble installing Openroads Designer. I receive the following error (see screenshot). I now finally managed to install version 10.05.00.30 and trying to upgrade to 10.6.0.38. I get the same error when trying to update through the Connection Client and when I download the installer. Any ideas?
Please try a clean uninstall/reinstall.
Preferences and Data
Save any edited files that you have changed.
Add/Remove Programs
Use Control Panel > Add/Remove Programs to remove all instances of OpenRoads Designer CONNECT Edition
File Explorer
Go to C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition and delete all directories.
Go to C:\ProgramData\Bentley and delete all folders with OpenRoads Designer or OpenRoadsDesigner within the folder name.
Go to C:\Users\firstname.lastname\AppData\Local\Bentley\OpenRoadsDesigner and delete all directories
Go to C:\Users\firstname.lastname\AppData\Local\Temp\Bentley\OpenRoadsDesigner and delete all directories
Go to C:\Users\firstname.lastname\AppData\Roaming\Bentley\OpenRoadsDesigner and delete all directories
Install
Turn off Windows UAC (user account controls in control panel)
Right click on ORD .exe and run as administrator
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Answer Verified By: Aernout Hoesintalib
This plus uninstalling connect advisor and reinstalling worked for me! Thanks!
only thing that worked for me:
https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
