We need the possibility to modify the named boundary by entering data.
We need to be able to change the plan boundary by station and offset.
We need to be able to modifiy the elevation AND lenght (station start and station end) of the profile named boundary.
We need to be able to change the cross-section named boundary station, left and right offset.
Those changes need to be easy.
Those tools need to work flawlessly.
And idealy we could apply those changes to many named boundary.
Hi, what is the status of this enhancement?
Thanks!
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
Not any time soon from what I hear.
Seriously... This is needed yesterday.
Just bringing this thread to the top.
Has this been resolved yet?
I'm using ORD 2020 R2 and I still can't find a way to edit cross sections named boundaries using some kind of dialogue box. If you have 10 cross sections and they all need to have different lengths and heights, how is this achieved. I'm having to edit the named boundary individually using accudraw and then re cut the sections. Would also be good if you didn't have to re-cut the sections every time, because using remove model annotations and re annotating doesn't update the annotation to the new shape of the named boundary.
Has anyone found a solution to this problem?
Hi think there is something in the 2021 R1 version but I didn't had time to try it yet. But still no way to edit the named boudary...
