ORD Feature Definition Volume Options
Hi all
Specifically for OpenRoads Designer.
Is there perhaps a list of the various Volume Option properties for a mesh feature definition that explains what each option does?
For example: Subgrade - Component modeled but does not contributed to cut of fill. Design - component forms part of top/bottom mesh and thus influences cut/ fill volumes.
Also, will there be the option to split the volume quantities of a component with the Design volume option in to in cut/ in fill? This is particularly important for subgrade layers which may be partially in-situ and partially imported material for a road widening project.
Parents Reply Children
