Is there a way to display all cross sections in a grid in a single model rather than splitting them up into a model for each section?
what product and version are you running?
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/175799/display-all-cross-sections-in-a-grid
OpenRoads Designer CONNECT Edition - 2018 Release 4 Update 6 - Verion 10.06.00.38
The only way is to do xs sheets
https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=110831
Answer Verified By: Brian Gacke
While there's no way to do this as easily as I'd like... It is possible to get a single stack of cross-sections for an entire corridor which can then be referenced/merged into a single model alongside other corridors so all your cross-sections are contained in a single file.
I created a cross-section sheet seed with a tall sheet size but standard width. Now, when I run cross-sections it creates individual drawing models but references all of them into a single sheet model that contains all cross-sections along that corridor. I then manually adjust the sheet model dimensions to trim the excess paper area as needed and plot to PDF which makes it easy to scroll through your corridor.
