I have watched a dozen (or more videos) read several how-to's and I still cannot figure out how to edit the boundary of my terrain model. Would someone please walk me through this.
I am using OpenRoads Designer CONNECT Edition (Update 2). I have a large topo survey of a 5 mile long, winding road. Because the road winds so much, there are large areas of the terrain model that contain no data and need to be removed.
I have tried:
Adding a boundary using Terrain>Edit>Boundary Options>Add Boundary (This doesn't seem to do anything)
Adding a boundary using Terrain>Edit>Feature Mangement>Add Feature (This adds a the SmartLine I've drawn, processes, but the boundary and triangulations don't change)
Deactivating Survey Processing Rules on the fieldbook and deleting the extra triangles (This just doesn't work at all. Even when the rules are turned off, the terrain model won't allow editing)
I may have done any one of these things incorrectly, I don't know.
I have become very frustrated at what ought to be a simple process, and really need some help here.
One of the things I have on my plate is a creating listing of which of the "standard MicroStation" tools are applicable to the civil geometry elements created in OpenRoads. I will see about getting that started here.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
I am having the same issue except I can follow the video up until I deactivate the survey processing rules. After deactivating the rules, when I try to delete triangle by line, I still get the message "Not an edible terrain".
The problem was that I had started from a 2d seed file. When I tried starting fresh with a 3d seed file I had no problems with the workflow.
