I am using OpenRoads Designer CONNECT 2018 Release 4 Update 6 10.06.00.38.
I need to restore configuration variables to default. I configured incorrectly while learning, then feature definitions do not load properly.
Dinusha
Try a clean uninstall/reinstall.
Preferences and Data
Save any edited files that you have changed.
Add/Remove Programs
Use Control Panel > Add/Remove Programs to remove all instances of OpenRoads Designer CONNECT Edition
File Explorer
Go to C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition and delete all directories.
Go to C:\ProgramData\Bentley and delete all folders with OpenRoads Designer or OpenRoadsDesigner within the folder name.
Go to C:\Users\firstname.lastname\AppData\Local\Bentley\OpenRoadsDesigner and delete all directories
Go to C:\Users\firstname.lastname\AppData\Local\Temp\Bentley\OpenRoadsDesigner and delete all directories
Go to C:\Users\firstname.lastname\AppData\Roaming\Bentley\OpenRoadsDesigner and delete all directories
https://communities.bentley.com/products/road___site_design/w/
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi Marcus,
Thanks for the reply. I tried with your suggestion but it did not work for me. Even I cleaned the registry files.
What I did, I copied configuration variables from other computer then resolved the issue.
Answer Verified By: Marcus Blake
