Anybody is having issues with Openroads? You can works for two day and everything is fine, product is stable, but then something happen and you can't pinpoint it. Your corridor do not recognize your profiles even if they are active, so you make them not-active then active again. But then you have weird error message that you can't do that because it's already active. So you have to drop them and recomplex, again. Then part of your annotation groups stop working, not reading the elevation of your active profile. Then you try to recreate your drawing model with the exact same drawing boundary and it's not working. So you create an other named boundary and now all the annotation are working fine. Then you go to your 3D model and you have your terrain mol that have been multiplicating for 200 times, so you detache all of them except th "good" one.
There is also the problems with Interval, when they work they are great. But when they break or loose their relationship and start to corrupt your file, you know you are in bad shape. You have to find them and delete them. You start selecting stuff, drop, select, delete, and you crash, reopen -wait because the software is slow and then after many many crash you finaly find the bad line or curve or whatever that keep you crashig for the last hour or more. So you have to find the good order of drop-delete-remove interval to finaly get rid of it and every time you do not do the right combination the software crash and close and you have to start again.
There is also the deleting of user preference folder and temp files. So you have to reconfigure your working environnement again.
I know openroads is great for modeling and the possibility are so great about this tools and how it COULD be, but all this greatness comes with a very bad taste and a lot of frustration.
We use to be able to clean up relatively easily or files with the display civil browser but now we can't.
We need a way to clean up files, an efficient way of removing bad elements.
Corrupted file.dgn
Here is my design file that I deleted everything and it is still corrupted. I even tried to copy only alignment from my file to an other file but the corruption follow.
