Help, I Cant Open DGNs from Projectwise Error [222]
I keep getting the below error when trying to open DGN Drawings from Projectwise but ONLY for drawings that i have created within Projectwise. If another user has made the DGN or I have created it offline and uploaded it i do not get the error.
The companies resident IT team has applied a fix which has worked in the past but it as not worked for me. Similarly we looked over the following guide : https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/35869/project-managed-workspace-error-starting-inroads-or-geopak-in-projectwise-connect-v10-00-02-265
This also did not work.
As a work around i am able to open a different drawing (one that I have not made in P'wise) and then inside Inroads I can open the problematic drawings with no issue.
Any ideas/help would be greatly appreciated.
  • John,
    Just out of curiosity, how do you start the software that is used to open the dgn files.
    From your screenshot I guess you use the program association that connects the filetype to the program and allow that to start the software.
    From my experience using MX and now ORD it is best to start the software form the desktop/start menu shortcut, log onto PW and then open the file you want.
    Jan
Reply
  • John,
    Jan
