Analyze volume tool(Cut&Fill volumes) is missing from Civil Terrain tools in PS SS4. Also key-in TERRAINMODEL ANALYZE VOLUME doesn't work. If Opensite Designer will replace PowerSurvey then it will also miss option to calculate volumes between terrains?
PowerSurvey v8i SS4
PowerCivil v8i for Country
Workaround: communities.bentley.com/.../cut-and-fill-volumes
Hi Oto,
this command is present in OpenRoads and I can see it in Help of OpenSite too.
Josef
Problem is that in PowerSurvey Help it is also mentioned but is not there so I would not count on it.
I understand, I have found similar issue for some other tool in OpenRoads. Regarding Volume Analyze in OpenSite good news. I tried to install and look at this. The command is included here too
