I´m have installed on my machine OpenRoads ConnectEdition. But I need MicroStation too. So my question is: do I need to download a full install of MicroStation and run it, or there´s a way to use the MicroStation's core that OpenRoads uses? (I'm used to be an Autodesk user, and for Civil 3D you can start it as a normal AutoCAD instance, by clicking separate icon created by Autodesk's install process.) As OpenRoads is built in MicroStation core, Civil3D is built in AutoCAD's core, so can I do this? unfortunately, after install OpenRoads, I can't find an MicroStation icon...
ps.: sorry for my bad english
You can start ORD as normal, but only use the MicroStation CAD functionality that is 'built-in' - there is no need to have a separate icon.
Answer Verified By: Fernando Borges
Thank you. So I can just create/open a .dgn file in ORD and use the Drawing/Modeling modes instead of OpenRoads Modelling mode. Is that right?
Correct.
