I just received a new computer and my Applications Menu is not loaded in Microstation SS3 to load InRoads SS2. How would I go about configuring this menu. We have a Managed Workspace on ProjectWise.
Joe, I am a little removed from my ProjectWise days, but you should be able to add it as a command line option under Tools > Programs. From there select the User associations in the drop down on the top right. Find your MicroStation and add -wsLoad_InRoads_SS2=1 as a Command Line Option.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022 / 2024
Thanks, I checked this area and the command line exists...…….
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
Here are the settings
I am surprised that the icon for MicroStation is not there...does the new computer have the same installation directory as the old? (Or as is shown in the association there?)
Hi Steve, we have narrowed it down to the data source, we have 2 data sources on PW. It works on one source but not the other. Bentley is assisting us with this. Stay tuned.....
