I need to export an annotated profile from OpenRoads Designer to AutoCAD. The export was successful for linework and the grid text, however the annotation text and curve data text is not displaying correctly (shown as 0's in screenshot below). Is anyone aware of a solution to this issue?
AutoCAD export - 2016 version - 2013-2017 compatible
OpenRoads Designer
Thank you,
Robert
can you send your files? ord and the exported autocad file? thanks
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/176863/autocad-conversion-from-openroads-designer---profile-view
Please find OpenRoad Designer file and AutoCAD export attached.
CAD Profile Export.dgn
CAD Profile Export_290EBEN_2.dwg
-Robert
CAD Profile Export.dwg
ok. I don't have autocad to test it but I opened it with ord and it looks good.
If you open the AutoCAD export, it does not display correctly. The ORD file displays it correctly. The problem is that I need to export the ORD profile (which is correct) to AutoCAD file format. The converted file shows all 0's.
-Rob
ok. I don't have autocad to test it. can you make a video of you opening the dwg in autocad and zoom in to show the text?
I will then use it to submit a defect. also, include the version of autocad
https://bentley.sharefile.com/r-rbf0b888133443ec9
