I need to export an annotated profile from OpenRoads Designer to AutoCAD. The export was successful for linework and the grid text, however the annotation text and curve data text is not displaying correctly (shown as 0's in screenshot below). Is anyone aware of a solution to this issue?
AutoCAD export - 2016 version - 2013-2017 compatible
OpenRoads Designer
Thank you,
Robert
Hi Roberto, I found out it has something to do with the attachment settings during the export process.When I set the self attachment to"merge" and export to dwg,I will get the profile and ground line but with "0" values on the curve vertical curve data.When I set the self attachment setting to "omit" and export,I will get the vertical curve details correctly but without the profile line and ground line.So, I can only combine them manually in ACad to produce a proper profile drawing. That is what I did as a go around for this problem it. If there is any other more effective methods please do share.Thanks
Did you find the solution???
I still don't think there is a solution but I have not tried in a while.
Try referencing your profile model into your default model, then export to dwg. It's working fine except in 2021
